Taskalfa 2554ci Scan error 4901
  • kyotechnz
    • Mar 2019
    • 130
    Have a customer with a Taskalfa 2554ci getting a scan error 4901 (scan to email).
    Firmware is up to date. The Test Button comes back Connection OK. All the settings as far as I can see are correct.
    The guy at Kyocera I deal with does not know what that error means but hopefully will find out for me.
    Have tried through a Gmail account and their company mail server.
    Has anyone seen this error before?
    • 29330
    Re: Taskalfa 2554ci Scan error 4901
    check the security settings and see if anyone turn off stuff that suppose to be on ie tls settings
      If you sync the time setting by using " time.windows.com", does it work? I always do this to see if I'm actually connected to the internet. I'd rule that out as a possibility at least.
      • Ropariva
        • 628
        You could try again with network settings on DHCP.
        Is it a new installation, IE new customer, or is it replacing an existing Kyocera?
        • kyotechnz
          • Mar 2019
          • 130
          I have heard back from our Kyocera rep and have been told what the 4901 error means.
          It is a "General failure code to validate certificate". Check SMTP Server certificate.
          Getting customer to check the certificates at their end.
          Will check encryption settings and SMTP security settings on copier.
          • AndresM
            • Jan 2016
            • 36
            You can tray setting DNS 8.8.8.8 and 8.8.4.4 for Google server , SMTP.gmail.com.
            Good luck.
            Andy
