4004i FEEF codes
  • nathicana
    • Aug 2008
    • 327
    4004i FEEF codes
    We recently put two of these 4004i machines at a customer location. Both machines are throwing FEEF codes like crazy.
    I can't find any reference to this code "FEEF". Firmware is 2.04. Investigation is underway as to what is being printed but probably nothing special.
    Previous machines were 4002i.
  • PrintWhisperer
    • Feb 2018
    • 452
    "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
    • kuby
      • Oct 2007
      • 1370
      Re: 4004i FEEF codes
      I would contact Tech support and maybe they can tell you what the error code is. I looked and you are right there is nothing pertaining to that code in the manual at all. Did you do a Total firmware install, not the Turbo but the Full install. That is one thing they have always told be to do. Also check the driver they are using, I think these machines use a different driver.
      • Scott
        • 189
        My question is how in the world did you get your hands on them????
          • 22917
          I've got nothing to add ... but I'll be interested in the results. My reference stops at "CFBxx", but it's 7 years old. =^..^=
          • kuby
            • Oct 2007
            • 1370
            KX print driver 8.0.2815 is the one they suggest to use
