Kyocera TA-307 code F4F6
  • peterthebest
    • Mar 2013
    • 5
    [Error Code] Kyocera TA-307 code F4F6
    Here is the problem . Intermittent problem with codeF4F6. THE machine crashes. I updated the firmware and the KX driver. I then configured the driver in KPDL. The problem remains.
  • Ropariva
    • 628
    Re: Kyocera TA-307 code F4F6
    • peterthebest
      • Mar 2013
      • 5
      Allo
      The problem is with win 10. Print in word or print email . THE KPDL , is a proposal from the Kyocera Hot line. But his rule not at all.
      Sorry for my english .
      I speak french .
        • 22916
        • Santander
          • May 2009
          • 768
          Allo
          I speak french .
          Your English is fine, not to worry. The KPDL driver is a postscript driver and even set to auto I have seen it have problems with text documents. The better setting is to use the KX driver which can handle either PCL or Postscript. Also only use the KX driver downloaded from Kyocera and not from Windows. Using the add printer function in Windows installs only a partial of the full KX driver which could cause problems.
