Kyocera M5521cdn. Imagenes pixeladas. Zonas grises
  • wackosco
    • Apr 2022
    • 5
    [Misc] Kyocera M5521cdn. Imagenes pixeladas. Zonas grises
    • 22916
    Good afternoon and thank you all for your contribution.
    I have a Kyocera M5521cdn, and it's driving me crazy, because when printing, all the images, the pixels and areas that should be white, appear gray. That is where it is most noticeable.
    What have I tried.
    1) I have changed the toners. (they are high quality compatible)
    2) I have updated all the printer software.
    3) I have tried from different computers, with different operating systems.
    4) I have changed the printer settings, setting it to the highest possible quality.
    5) I have tried a HARD RESET, but it has not been possible, because it stays blocked and only allows me to turn it off.
    I DON'T KNOW WHERE TO FOLLOW...
    Can someone guide me a bit?
    Thank you very much.
    • wackosco
      • Apr 2022
      • 5
      2R9_2000.001.310)
      [QUOTE=blackcat4866;2137570][/CITA]
      • sparkycivic
        • Apr 2017
        • 348
        Re: Kyocera M5521cdn. Imagenes pixeladas. Zonas grises
        Is there any C76XX in the log??
        calibration might be maxed out due to failure of automatic cal caused by dirty sensor, dirty belt, or drum cleaning failure.
        • CWP
          • Jun 2013
          • 168
          • mad
            • Jul 2010
            • 25
            la impresion de la "pagina de estado" (status page) se imprime bien?
            • martinar
              • Mar 2017
              • 27
              • wackosco
                • Apr 2022
                • 5
                Originally posted by mad
                la impresion de la "pagina de estado" se imprime bien?
                • wackosco
                  • Apr 2022
                  • 5
                  • wackosco
                    • Apr 2022
                    • 5
                    • martinar
                      • Mar 2017
                      • 27
                      [QUOTE=wackosco;2142464]
                      Originally posted by martinar
                      [ATTACH=CONFIG]53200[/ATTACH]
                      • JVergin
                        Service Tech / IT Rep
                        • 216
                        When I see this type of anomaly:
                        - Printer Properties
                        -- Imaging Tab
                        --- Color Reproduction Dropdown Menu
                        ---- Choose 'Publications".
                        This setting will usually get rid of issues like this where it prints digital noise in areas that are supposed to be transparent.
                        • LGMiranda
                          • Jun 2022
                          • 1
                          I have the same problem. Did you solve it?
