Kyocera M6630 Screen Message That Toner Is Empty Even Though New Toner Is Installed
  • CopyTech1975
    • Oct 2021
    • 17
    [Misc] Kyocera M6630 Screen Message That Toner Is Empty Even Though New Toner Is Installed
    Customer completely ran machine out of black toner, so after replacing with new toner I still get the message that the toner is empty. The error message locks out service mode and I cannot perform developer refresh. I thought maybe if I replaced the black developer the machine might recognize that the toner needs to be added. Anyone seen this before? is there another solution? Thanks
  • lees
    • Apr 2011
    • 94
    Re: Kyocera M6630 Screen Message That Toner Is Empty Even Though New Toner Is Install
    Open and close the rear door and the waste toner door. If either one of these is not closed properly, the machine will recognize the add toner before the open door. Open and close all doors and make sure each one is closed properly and that should solve the issue.
    • CopyTech1975
      • Oct 2021
      • 17
      lees,
      Thank You Very much, this fixed my problem. On first look it seemed like the rear cover was closed, But it was ajar.
        • 22920
        This happens every single time the top cover is opened. =^..^=
        • CopyTech1975
          • Oct 2021
          • 17
          Yes I'll have to keep watch for this, as customers change their toners on this model. Could be a repeating problem. Thanks
          • citeog3
            • Jan 2013
            • 11
            Had this with compatible toner. Take the toner chip off. Power machine back on and follow past the warning messages. Then refit the toner chip.
