Hey everyone!
After taking a two year break from the industry, I'm back in action at a Kyocera dealer.
I initially went to the machine because the lead edge of the original was catching on the exit sensor flag. it was gummed up from a failed noise dampening pad. When i put it all back together it won't feed one single page into the thing. After a lot of tests, i ran in simulation the motor for the pick-up rollers and its running in REVERSE!!!
So for someone that works on these document feeders, What can cause this motor to run in reverse? I have triple checked all my connectors on the DP board no luck.
Has anyone seen this before? Any ideas?
Thanks Y'all!
Thanks Y'all!
