Kyocera TASKalfa 6003i Light Prints
  • Tommy Chilcott
    • Jul 2018
    • 10
    [Electrical] Kyocera TASKalfa 6003i Light Prints
    Good Morning.
    I have a machine that is printing light. I have done the following:
    Updated Firmware
    Stripped and cleaned all springs that make contact with the HV PWB
    Checked and cleaned Secondary Transfer Roller.
    Changed the paper.
    Replaced DK and DV.
    Replaced HV PWB.
    As per Manual it states it could be Engine PWB. I would like a second opinion?
    Kind Regards
    Tommy ChilcottPongola Academy04338320220801124002.pdf
  • pascalb.
    • Aug 2016
    • 47
    Re: Kyocera TASKalfa 6003i Light Prints
    Hello,
    I have this BT which corresponds to your machine
    Blank image.pdf
    to check
    Do not lament,
    do not mock,
    do not hate,
    but understand.
    • copiertec
      • Jan 2016
      • 2184
      Are you using OEM toner?
      • dalewb74
        • Feb 2018
        • 1107
        so it just prints lightly? or it copies lightly as well?
        • progoffice
          • Nov 2008
          • 333
          It has been awhile, but I remember getting in a used CS 4002i having similar issues. We did like you and tried just about everything. Ultimately, replacing the engine board corrected the issue for us. I would definitely give it a try if you haven't already. Good luck!
          • sparkycivic
            • Apr 2017
            • 348
            can you mark the developer and confirm that it is being rotated?
            Also, make sure to go through all the screws on the power supply board for tightness. I've had a lot of issues with loose screws upsetting the power supply ground connection and popping downstream boards with bad output.
              • 22916
              Have you emergency stopped the machine and checked the latent image on the drum and primary transfer belt? That will tell you at what point you're losing your HV. =^..^=
