Kyocera Taskalfa 8353ci
  • brunot
    • May 2012
    • 148
    [CQ] Kyocera Taskalfa 8353ci
    Hello everybody,
    White strips appears only on color image.
    Please advise.
  • toddanderson
    • Dec 2005
    • 231
    Re: Kyocera Taskalfa 8353ci
    Laser is filmed, dirty
    Originally posted by brunot
    Hello everybody,
    [ATTACH=CONFIG]54647[/ATTACH]
    [ATTACH=CONFIG]54648[/ATTACH]
    Please advise.
    • PrintWhisperer
      • Feb 2018
      • 452
      Not seeing this as much but still popping up I guess.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • brunot
        • May 2012
        • 148
        I've performed the Laser cleaning (Adjustment & Maintenance Mode): same issue
        I think I need to dismantle and check the Laser unit.
        • brunot
          • May 2012
          • 148
          Originally posted by PrintWhisperer
          https://www.copytechnet.com/forums/k...5=#post1838201
          Thanks!
          • PrintWhisperer
            • Feb 2018
            • 452
            LMAO. Go for it. JUST KIDDING...children...don't play with Lasers.
            They are sealed and they quit blowing air through them in the Voyager series.
            There is nothing to clean or replace inside.
            • brunot
              • May 2012
              • 148
              I will first try the U467 on Monday morning and will let you know...
              • brunot
                • May 2012
                • 148
                Well noted, thanks.
                • brunot
                  • May 2012
                  • 148
                  I've followed your instructions regarding U467 and the machine is working properly.
                  Thank you, much appreciated.
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1855
                    Good in theory, but not the real world. Unfortunately I have to pull the laser on a few Alphard & Alphard 2's in environments where the end of the polygon mirrors get dust build up.
                    It looks similar to this, but all 4 lasers exhibit the same thing. I've even tried to seal the laser unit with tape, but it did not help.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • PrintWhisperer
                      • Feb 2018
                      • 452
                      Good job OP!
                      Yeah when the warranty is up you can chance it, but this is a new machine. No sense when there is warranty coverage, you're just risking a voided return.
