KYOCERA "close the back cover"
  • An3as
    • Sep 2022
    • 1
    Hello
    I've got a printer KYOCERA ecosys 5021cdn,
    the copier says to close the back cover, but the cover is closed.
    I manually push on the sensor, but it still says it is open.
    Is there any way to tell what the problem is?
    thank you in advance
  • copykat93
    • Oct 2021
    • 268
    Re: KYOCERA "close the back cover"
    I'm not here to downgrade anyone...BUT... are you a tech? Seems pretty straight forward, a tech would try all the obvious things ... micro switch for activation, tab on back door where switch activates, can you hear the micro-switch click? Did you meter it for differences when activating? So many questions ......
    • PrintWhisperer
      • Feb 2018
      • 452
      I have not been in one of these frames for a while, but the predecessor had the TOP cover ACTUATOR and the REAR cover ACTUATOR tied together mechanically (was a clear plastic ribbon- right side mid-level). The mechanism would become fouled and usually indicate rear cover open.
      NOTE: I said ACTUATOR - in that case the door plunger is NOT a switch. The switch was behind the right cover under the mechanism tied to the plungers.
      Pull the right covers and check it out.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
        • 22917
        Is this the same mechanism that went through modifications on the Gemini series? I've been into those. It's a major disassembly.
        • PrintWhisperer
          • Feb 2018
          • 452
          That's the one. The dual switch actuator has a 'tug of war' between the 2 door actuators with a thin ribbon of polymer 'tape' as the rope. Funky guides, runs behind the control board, not fun.
