M2535dn firmware update with Net Viewer
  • dneuhaeuser
    • Feb 2023
    • 1
    Hello,
    I have a Kyocera Ecosys M2535dn on one of our sites with quite old firmware version 2PL_2000.003.032.
    Trying to update it with Kyocera Net Viewer, I always get the error "version check failed" (translated).
    I tried both firmware 4.107 and 5.109 from here:
    Kyocera ECOSYS M2535dn Firmware - BesLand
    Also I'm not quite sure whether to start with DL_CTRL.2PL or DL_ENGN.2PM since I can only select one at a time.
    But I get the same error no matter what I try.
    Does someone have experience updating this model remotely?
    Regards
    Dennis
  • diedux
    • Jan 2017
    • 124
    Re: M2535dn firmware update with Net Viewer
    Hi,
    Firstly, get proper firmware files. You should look for ECOSYS_M2535dn_v.05.05.0020_(2017-10-12) archive.
    Then, use the DL_NWDL.2PN file when selecting a firmware file in NetViewer.
    Good luck.
    • dalewb74
      • Feb 2018
      • 1107
      what about just updating it on the machine itself?
      • likomit
        • Jan 2024
        • 10
        • Format USB drive with FAT32
        • Copy firmware files to the USB drive
        • Turn the machine off.
        • Insert the USB stick into the slot below the control panel (next to the power button).
        • Turn the machine on.
        • Wait a few seconds, and the firmware should start updating.
        • Once the firmware update is complete, turn the machine off.
        • Remove the USB stick & turn the machine on again.
