Kyocera ECOSYS M6230cidn no OCR dictionary data
  • AlexZX
    • Mar 2023
    • 4
    Hello,
    I have a ECOSYS M6230cidn.
    Last week I purchased the Kyocera Scan Extension Kit (A) and installed the license. I have also the HD-7 SSD (128 GB)properly installed.
    When I turn on the machine I get the following error "OCR dictionary data is not properly installed. OCR Text Recognition may not be correctly performed".
    Can someone tell me where I can get the OCR dictionary data to install it on the SSD?
    Thank you!
  • CWP
    • Jun 2013
    • 168
    Re: Kyocera ECOSYS M6230cidn no OCR dictionary data
    Alex, it is contained in the firmware and should automatically install when you perform a firmware update with the SSD installed.
    • AlexZX
      • Mar 2023
      • 4
      Hello, thank you for your reply.
      it seems that I have already the latest firmware on my machine. When i try to update it with the Firmware Upgrade Tool (1.0.7.28) it tells me that I already have the latest version.
      Can I force the update somehow?
      Thank you very much!
      • CWP
        • Jun 2013
        • 168
        You should be able to upgrade the "old fashioned" way of downloading the firmware to a USB drive and powering the machine on with USB drive inserted in the machine's USB port.
        • Samanator
          • Sep 2017
          • 571
          I would suggest not to use the 'Turbo' firmware version when loading firmware on a USB drive in your particular case. This will force the machine to upload ALL the new firmware.
          I always do my firmware updates with a USB drive. IMHO it is the surest way to do a firmware update. Once, and you're done.
          I have had problems with Firmware Upgrade Tools to the point it is no longer worth the time for me to deal with them.
          I hope this helps.
          • AlexZX
            • Mar 2023
            • 4
            On the Kyocera website I can only download the "FirmwareUpgradePackage_ECOSYS_M6230cidn_M6235cidn_ v03.03.0030.fwp" file.
            Is it the right one to copy on USB drive?
            Thank you very much for!
            • AlexZX
              • Mar 2023
              • 4
              Just tried it, does not work
              I formatted the USB flash drive with FAT32 and copied the "FirmwareUpgradePackage_ECOSYS_M6230cidn_M6235cidn_ v03.03.0030.fwp" on it. Put it in the printer's USB port and turned it on.
              But no firmware update started. The printer just asked me if I want to search the USB for files. If I click yes, I only see the empty drive. The printer does not see this file.
              I remember on my old FS-C2126MFP+ the firmware consisted of 4 files. But I can't find such firmware for the M6230cidn.
              Can you please tell me where to get the right firmware to flash from USB?
              Thank you!
              • dalewb74
                • Feb 2018
                • 1107
                try a different brand thumbdrive. i don't remember the brands, but i have had a few that a specific brand doesn't work for whatever reason.
                • KYO_OEM
                  • Aug 2011
                  • 684
                  See enclosed instruction.
                  OCR.zip file you`ll find in the FW package.
                  After formatting from SSD you connect USb key with FW and went into system menu for installation.
                  • ntbann
                    • Jan 2012
                    • 622
                    Once the file is unzipped to the drive you must take all files from the folder and copy them to the root then delete the empty folder.
