Kyocera color modes
  • kuby
    • Oct 2007
    • 1370
    Kyocera color modes
    I know that there is a mode that you can tell the Kyocera to color print like a Ricoh, Canon, HP or others. Just do not know where it is or what it is called.
  • ntbann
    • Jan 2012
    • 622
    Re: Kyocera color modes
    U485 color tables
      • 29276
      If your using the KX driver you can also change the emulation from Pcl KX to Pcl5c or Kdpl
      Under the device settings tab
      • PrintWhisperer
        • Feb 2018
        • 452
        In MM485, you can set (2) color tables for each of Copy and Print.
        Color Table (1) becomes default, Color Table (2) is selectable from the driver 'Imaging' tab->Color Reproduction or panel 'Image Quality' setting being set to 'Custom'
        If the HDD has been formatted, Color Tables are gone and must be restored by Firmware re-installation.
        "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
          • 16309
          I didn't know that. Thanks.
          • kuby
            • Oct 2007
            • 1370
            Thanks, just couldn't remember where it was.
            Have not used it in about a year.
