F248 code. 4054ci
  • toddanderson
    • Dec 2005
    • 231
    F248 code. 4054ci
    I have an account with having several f248 codes daily
    on 4054ci I have updated the firmware and print drivers
    just have a hard time tracking it down
    doe seem like printing pdf from chrome has the issue more
    just looking for some tips on what to try
    • 16309
    Re: F248 code. 4054ci
    F248 is a corrupt print job from prining from webpage. Best solution is to turn on Auto Clear Fuction. Set it to "on."
    If you go to the timer settings in system menu on the machine. Auto error clear is in that menu, turn on and it's defaulted to 30 secs.
    IMPORTANT -- Make sure drivers are updated and latest firmware is installed.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1855
      I had one doing the same thing. I ended up switching the IP address of the MFP to troubleshoot. It turned out, I tracked it down to a PC that was printing to their old Sharp at the same IP address. The printer was removed from the printers & devices, but the queue was still there in the print spooler with the pending jobs stuck in it.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Ropariva
        • 628
        • copier tech
          • 8093
          My money would be this being the cause.
