White screen on TASKalfa 2554ci
  • Exodia-P4
    • Jan 2023
    • 123
    Hello everybody
    After a thundurstorm, one of my 2554ci at a customer reboot and display a white screen... I have reboot, unplug but its same...
    I will go this afternoon test an update. I dont know if the copier start normally or just display white screen (It can change the mistake). I brought a screen in case of...
    Have you already have this mistake ???
  • kuby
    • Oct 2007
    • 1370
    Re: White screen on TASKalfa 2554ci
    Hope that it did not damage the control board. Had one that was not on a surge protector that it came in through the network cable and had to change the control board. All copiers now have a surge protecting the power and network, even if we did not sell the machine, we tell the customer what will happen if a surge comes it and it is not protected. $$$
    • PrintWhisperer
      • Feb 2018
      • 452
      Originally posted by Exodia-P4
      Hello everybody
      White screen problem has been seen, but not for lightning/power surge. So perhaps you have a different problem like Op Panel Main or Main PWB...BUT
      Try to remove the network cable and reboot. If it helps I'll tell you why.
      "Being ignorant is not so much a shame, as being unwilling to learn" - Benjamin Franklin
      • ricohmaina
        • Dec 2011
        • 20
        I'm intrigued. How does the Network board cause a white screen?
        • PrintWhisperer
          • Feb 2018
          • 452
          By crashing the OS. May need experimental firmware to fix it so contact your support rep.
          Black screen+Sleep light blinking->Remove network cable and white screen may appear. Also Panel lock may occur with some network operations.
          Caused by failed network process (internal) under certain configurations. Check for complete network configuration.
          • Exodia-P4
            • Jan 2023
            • 123
            Hello and thanks everybody for your answer
            The problem is the Main card. The Internet box caught lightning and the lightning follow the RJ45 cable... and BOOM
            I see the RJ45 controller on the board is burnt, I can see the silicon chip
            thank you and see you soon
            • kuby
              • Oct 2007
              • 1370
              Be sure if you install a new board to put the copier on a surge protector with power and network protection.
              • Exodia-P4
                • Jan 2023
                • 123
                Yes, it what I said to my customer
                • ntbann
                  • Jan 2012
                  • 622
                  Hope that is all it took out. I had one get hit through the nic and it took out my msat also. We forced the customer to make a insurance claim.
                  • Exodia-P4
                    • Jan 2023
                    • 123
                    Now, for all electric card, we say to the customer to make a insurance claim. It's not in the contract.
