Copystar CS5053CI C7404 error
  • copier monkey
    • Oct 2016
    • 8
    This si a strange one I was hoping someone could point me in the right direction on. Had a machine for lease return that I was pulling good parts from and installing older stuff to return with. (they tested fine in their original machine but were high use.) I installed a yellow developer and was greeted with a C7404 error. Installed the original and error did not go away. Updated F?W as directed in the manual and still no dice. Tried another used yellow dev unit I had had in stock with no change. Called Kyocera and ran thru their scenarios to no avail. Anyone got some ideas on this?
  • Ropariva
    • 628
    • KYO_OEM
      • Aug 2011
      • 684
      Re: Copystar CS5053CI C7404 error
      Have had similar case with dk unit.(C790x)
      Bent pin from unit breaks drum developer relay pwb + feed image pwb
      Exchange from all 3 parts together needed
      What do you see at U117 and U984?
      Missing all serialnumbers or yellow only?
      All empty ---> drum developer pwb broken
      What do you see at U122?
      SN from Belt or not?
      No serialnumber from belt also ---> feed image pwb broken + drum delevoper relay needed
      By the way: don`t use DV-8550 instead of DV-8560
      • copier monkey
        • Oct 2016
        • 8
        Just checked when I got into the shop. All serial numbers present and accounted for. Also checked to make sue it was a DV-8560. Wondering if a new Dev will knock some sense into it, but don't want to burn a new unit unit to test.
        • KYO_OEM
          • Aug 2011
          • 684
          take drum developer relay pwb from older system and check dv connector for bent pin
          • copier monkey
            • Oct 2016
            • 8
            [ATTACH=CONFIG]59870[/ATTACH]
            This is the board under the Drum/ Dev section correct? These connectors are female not male. The dev connector is male and has no bent pins.
            • KYO_OEM
              • Aug 2011
              • 684
              i don`t know why, but someting went wrong during mounting from the new or used dv unit.
              From now on the system won`t recognize any new yellow dv unit and you want to find why.
              I would start with drum developer relay pwb, the 1. pwb for drum + dv controlling.
              1 additional question: does the yellow dv units are working in the other system?
              Assemble dv unit, start up with open front cover and/ or conveying unit, enter maintenance mode and check serial numbers and counters.
              2. question: did you unplugged the power plug from the system or wall outlet before start from work?
              --> are the counter readings are logical or not
              --> same for history by U985, runtime by U157
              • copier monkey
                • Oct 2016
                • 8
                The DV unit works in other machines without issue. The serial numbers show up for the drum installed. Will look at history when I get back to the shop.
                • KYO_OEM
                  • Aug 2011
                  • 684
                  you do not have problems with drums, sn from drums not needed anymore, serialnumbers from dv units needed. visible by U984, history by U985
