TASKalfa 3553 - C1950 EEPROM error
  • kuby
    • Oct 2007
    • 1370
    I have a Kyocera Taskalfa 3553 that is throwing a C1950 code. I have gone through all the checks suggested and tried a new transfer belt. I have not replaced any of the boards yet I wanted to see if someone may have had experience with this error before I play parts darts with it. Have any of you experienced this issue and if so what did you find.
  • Ropariva
    • 628
    Re: TASKalfa 3553 - C1950 EEPROM error
    The small plug at the top centre of the belt unit is usually the cause. There is a bulletin about pins getting bent, but usually just wiggling the position of the plug at the copier up or down a little and restarting will resolve it.
    Sent from my iPad using Tapatalk
    • kuby
      • Oct 2007
      • 1370
      I looked and did not see a service bulletin on this. Could you share it please. It is driving the other tech nuts.
      • Ropariva
        • 628
        Belt.pdf
        • kuby
          • Oct 2007
          • 1370
          Thanks. Will show that to him and hopefully this will fix it.
          • kuby
            • Oct 2007
            • 1370
            Thanks that fixed it.
            • Ropariva
              • 628
              Awesome. [emoji106]
