I don't work on these alot, usually working on Ricohs. Replaced maintenance kit and then it showed a jam in the rear of the machine after turning on. Couldn't get it past the jam message. Did the following:
Checked all sensors and actuators for proper operation.
Made sure all connectors were properly seated and no bent pins.
Put original fuser and drum units back in machine, no help.
Ended up pulling machine into shop cuz I had other places to get to. Since then, I blew out all sensors with air and that got the machine to start cycling so I thought I was good but then it indicated a jam under the drum. After rebooting a couple of times I then got a 0800 error(controller error). Rebooted again and now I'm back to a jam error in the exit area.
I don't know WTF I did but any help would be appreciated as I'm ready to take a large hammer to it! Thanks
