Hello everybody
Sometimes, I have a jam 4201 on a customer's TASKalfa 7353ci. The paper is stuck and folded like an accordion between the two fusing roller (the customer cant take off paper and I must came in order to disassemble fusing unit).
I have changed fusing 1 year ago, changed paper feed roller 1 month ago. I change the margin front and the problem appears again.
I return today and I see that the jam is when the back enter in the fusing unit... and on the back there is a big picture which stuck on the fusing roller. I increase margin in back and the problem dont appears again.
Do you already have this problem ? I have lots of this error codes on Kyocera...
Thank you
Thank you
