Kyocera Net Viewer Questions
  • Thayer
    • Dec 2017
    • 107
    Good Evening All.
    I just started using kyocera net viewer again, a year away from kyocera's....
    What are the common things that get turned off on the copier, by IT or customers! Not allowing netviewer to access it.
    I had a list but it has been deleted. :-(((
    Example I tried to access a TA3501, my net viewer couldn't find it. So I 917 it, and couldn't transfer scan to email setting.
    Any help would would be great!
    Have a great weekend
    Thanks in advance
  • PiniuBudyniu
    • May 2023
    • 16
    Re: Kyocera Net Viewer Questions
    As far as I know, you can't export scan to email config using U917. For NetViewer check SNMP and credentials (if not default). Also, make sure Your NetViewer version is compatible with Your device. I always download the one from download section of the newest Kyocera device. I am from Europe though.
      • 22916
      I haven't used Net Viewer in a number of years, but I can share a few things:
      *a new version of Net Viewer is released with each new set of models, so the version changes several times each year.
      *each time the version changes, so does the functionality & features. Each family of machines is a little different, so it's an ongoing learning process to successfully use Net Viewer.
      *if you're doing IT work every day, it's no problem. It will be easy for you. In my position I used it once a month maybe, and it seemed that I needed a new version every time I opened the utility. For me, it was a PITA.
      If there was a way for the encryption and basic utility operation could stay standard for any length of time, it could be quite user friendly. =^..^=
      • Thayer
        • Dec 2017
        • 107
        Thanks, yes I have the most current version.
        I just remember customers IT turn off different things, and net viewer and web access won't work.
        • Ropariva
          • 628
