FS-4200
  • Dark Helmet
    • May 2009
    • 835
    FS-4200
    Howdy folks,
    I got a FS-4200 that just hit 500k. Time for Maintenance. The book says you can go to the Menu and Maintenance and reset it from there. I tried this on a FS-2100 which is the same manual and that option ain't there.
    Apparently you have to use a USB stick and FRPO commands? The book is a little vague. Anybody have some insight into this? Never had to deal with FRPO commands before.
  • nathansipe
    just another tech
    • Aug 2009
    • 122
    Re: FS-4200
    I have not tried it on the 2100 (300k), but I've done the 4200 (500k) on dozens. We've now moved on to the P3150dn models and from memory, I believe they are the same. Replace whatever parts it needs, then under the service menu, press maintenance, and it will reset the counters for all MK parts (drum, dv, trans, fuser, etc.) Then reboot the machine. If you are replacing the developer unit as part of the maintenance kit, choose developer (may say new developer) in the service menu. Then reboot. It will automatically run the add toner to the dv since you just told it you replaced the dv unit. If you didn't replace the dv unit, do not select developer reset in the service menu.
    Sorry I can't help with the 2100 specifically, but it looks like its the same procedure in the manual.
    Counter reset for the maintenance kit
    Description
    The "Install MK" message means that maintenance kit should be replaced at fixed pages
    of printing. The interval counter must be manually reset using this service item.
    Maintenance kit MK-3102 (for 120 V ) (40 ppm) :300,000 images
    Maintenance kit MK-3132 (for 120 V ) (60/50/45 ppm) :500,000 images
    Maintenance kit MK-3100 (for 230 V ) (40 ppm) :300,000 images
    Maintenance kit MK-3130 (for 230 V ) (60/50/45 ppm) :500,000 images
    Maintenance kit includes the following units:
    Drum unit
    Developer unit
    Transfer roller assembly
    Fuser unit
    Paper feed roller assembly
    Retard roller assembly
    Purpose
    To reset the life counter for maintenance kit.
    Method
    Drum unit (see page 1-5-15)
    Developer unit (see page 1-5-13)
    Transfer roller assembly (see page 1-5-16)
    Fuser unit (see page 1-5-19)
    Paper feed roller assembly (see page 1-5-8)
    Retard roller assembly (see page 1-5-8)
    Method
    1. Enter the Service Setting menu.
    2. Select [Maintenance] using the cursor up/down keys.
    3. Press the OK key.
    4. Select the [YES] using the left select key.
    [Completed] is displayed.
    The counter for each component is reset immediately.
    Good luck.
    Best rule for troubleshooting.
    K I S S Keep It Simple Stupid
    • Dark Helmet
      • May 2009
      • 835
      Re: FS-4200
      Description
      Drum unit
      Developer unit
      Fuser unit
      Purpose
      Method
      Method
      Good luck.
      I wonder if that option does not show up unless the new drum pops something and allows the message to show up. That machine has had a bunch of parts, none of them made it to 500k. Last drum that went in was a used one.
      • Dark Helmet
        • May 2009
        • 835
        Re: FS-4200
        Got this sorted. The machine does have a reset option from the panel but the machine must be in a "Time for Maintenance" state for it to show up.
