8030 6030 clean slit glass
  • jasonimage
    • Mar 2009
    • 12
    the machines keep telling us to clean the slit glass,why do they always do this,some far to often and what do we need to do to stop this?
    • 22920
    The machine is noticing that certain pixels of the image are always black. The most obvious conclusion is that whatever originals your customer is running are bleeding onto the slit glass, and that it just needs cleaning frequently.
    The official word from Kyocera is that the copyboard glass and slit glass cannot be cleaned with alcohol, because it will remove an "antistatic coating" on the glass. More practically it's just ridiculous to ask customers to dry wipe the slit glass. I just doesn't do any good. Plus the customer has a hard time even seeing ink spots.
    For customers that get this indication I recommend using alcohol wipes, and have had no negative consequences. =^..^=
    • usn.shaft
      Under the service menu you can turn that feauture off, I cant remember what number it is now, when I get to work I'll check.
      • KyoceraChris
        • Jun 2009
        • 112
        u326 should turn off the prompt to clean the slit glass..
        you gunna eat yo corn bread?!?
        • vikingmita
          • Nov 2008
          • 163
          -glass can be dirty on the underside, or dirt on any of the mirrors or the white deflector (who's guiding the sheet past the slit glass) on the doc.feeder can have dark spots/lines on it. that's about all.
          • daveh
            • May 2005
            • 13
            What does KM expect you to do when some ink doesn't wipe off, throw it away and buy a new glass (or machine)?
            • vikingmita
              • Nov 2008
              • 163
              ahh...you did clean upper scanner-glass too? just checking the obvious
