Kyocera km 2050
  • Luther
    • May 2006
    • 682
    Kyocera km 2050
    Just got 3 of theses in with low meters all under 40k with duplex,radf.internal finishers and fax options I was wondering what you think of these boxes and if anyone has a copy of the service manual for these machines, thanks in advance
  • 10871087
    • Jan 2005
    • 1143
    They are great machines. The operation panel is a little low and the doc feeders are a little lightweight but the machines are very relaible and will be money makers for you.
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      We've had several laser issues with this model. Also, make sure you have a MK-410 drum in stock for replacement. Customers have a tendancy to do the old reach in for jam removal and damage the drum. Otherwise not to bad of a machine.
      My mission here on Earth is to help all you Dum-Dums!
      • Luther
        • May 2006
        • 682
        Thanks Kyoceradude for the information, someone told me to put the machine in quite mode to help with the life of the laser, I am going to try it on the machine i am using as a printer in my office, seems to be a nice little box other then th low op panel and it was east to install to my network, thanks again for the info and if anyone has a copy of the service manual it would be greatly appreciated
        • JSC
          Gimp
          • Dec 2006
          • 618
          Yea its a good box, i tell my customers not to bother cleaning the charge assy, too many damage the charge assy's or the drum unit, but all in all you should have no real issuse with these machines.
          The gene pool could use a little chlorine.
          • Duke
            • Sep 2005
            • 19
            KM 2050
            These are great little machines, just have to keep them clean and they will work well for you, also install with a good power isolater or protection cord. It weill save you some grief.
            • cboucher
              • Apr 2025
              The biggest problem with those machines in the fact that the maintenance kits always seem to be on back order from Kyocera. Other than that, not a lot of problems.
              • scottdurnford
                these are good box most my problems with them are customer created. Did you find the manual? If not I have service manual for 1650 2050.
                • Luther
                  • May 2006
                  • 682
                  Thanks Scott a local dealer gave me a copy on disc,thanks again guys!!
                  • iggynerd
                    KM-2050 Finisher..
                    There is a Finisher which mounts on the Left side of the machine (I believe is the DF-78, not sure) If that is the one you mean by internal, I have heard from techs in the company I work for that they're a piece of crap, otherwise, as stated above, it is a nice little machine, just instruct your customers not to clean the MC Grid (And/Or not to install the Grid Cleaner that comes with the Toner Cart)
                    • Montana Tech
                      • Sep 2007
                      • 20
                      I had more problems with the Internal Finisher than anything else on these.
                      Had a couple drum units that were warped, so they wouldn't slide into place. I've also seen a few (new) damaged fusers - broken heaters. At one point, Kyocera manufactured the cover with the blue toner cartridge lock the wrong size. I had to take pictures of the original and the part they sent next to a ruler to prove it. They sent the lot of them back to Japan.
                      There's a squeak that can occur due to pressure on the drum unit.
                      Did I have a dream, or did the dream have me?
                      Kyocera-Mita/Konica-Minolta/Ricoh-Lanier
                      HP/Lexmark/etc etc etc
