I was initially told by my customer that the error code of the Kyocera Mita KM-4530 was a C0640, which is a hard drive error. However when I came to the copier it had a C0610 error code on the display. I addressed this problem last year by replacing the Main Circuit Board on the copier which seemed to work, atleast until now. The circuit board I used however came out of a working machine that I bought to use for a parts copier, so I knew that the circuit board was working. Is it possible I have had the bad luck of two bad circuit boards, or could something else be causing this problem? I am however wondering if the main switch can be a cause to the problem, because it doesn't feel as I think it should. Any help appreciated, thank you.
C0610 Error Code
I would check and re-seat all the connectors and the DIMM on the board. Make sure you don't have any bent pins, and make sure you don't have a bad ground somewhere. Then reload the firmware, and give it another shot. If that doesn't get you anywhere, then you probably will have to replace that board. If this is a recurring issue, I would try to find out what caused it first.I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark TwainComment
I agree with Metalvoc. I'd focus on the DIMM, and firmware. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
You should also run memory resets after flashing the firmware. I've had a few C06XX codes that wouldn't go away with just a firmware update by itself.But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
Re: C0610 Error Code
would the error screen still be up and the firmware be updating at the background?
I get 'program loading.." then few seconds later it switches to #################### call service C0610Idling colour developers are not healthy developers.Comment
