Edge to Edge printing
  • daveyball
    • May 2009
    • 314
    Any one know how to do edge to edge printing on the new Kyocera Colour MFP's, the customer is prepared for the extra toner costs. By default the machine is putting a 4mm border all the waty around, they would likt it redusec to say 2mm or non at all. I have tried to fool it by telling it it's oversize A4, A3 etc, and adjusting the margins in service mode.
  • inutelkamo
    • Jul 2011
    • 143
    Re: Edge to Edge printing
    i think.. its not possible for laser printers...
    why??
    your paper might jam..
    separation claws may got problem separating your paper from the fixing roller...
    • Metalvoc
      • Sep 2008
      • 155
      Agreed. There are several reasons a laser printer needs a margin on the page. I have worked with some print shops that do full bleed on laser printers, but they print on 12x18 paper and trim the edges.
      Adjusting your margins so that the print reaches the very edge of the paper will not only create quality issues near the margins, but will likely cause mechanical problems as well.
      I must have a prodigious quantity of mind; it takes me as much as a week sometimes to make it up - Mark Twain
      • JimHegs
        This Space For Rent
        • 108
        "full bleed" printing is done by printing an 11.25" x 17.25" image on some 12 x 18 paper and then trimming the excess. The Kyoshiba's and newest TASKalfa color can handle the 12x18 paper.
        https://cdn2.project-gc.com/StatBar/...cludeLabcaches
          • 22916
          Yeah davey, you've got to trim to get full bleed. Laser printers of all sorts require voids. There's no way around it. And even if you do find a way to remove the voids, you'll get fuser jams like crazy.
          You'll only make your life more of a living hell. An endless cycle of return calls for fuser jams. =^..^=
          • RRodgers
            • Jun 2009
            • 1950
            Easy fix,
            Just print on the next size paper up and cut it down. THIS IS HOW IT'S DONE. Wanna get around the digital boarder... fine... don't piss and moan when you get dirty copies.
            • flimmer
              • Jun 2008
              • 30
              You must reduse printermargings by adjusting Laser margin in the servicemode if its a MFP
              • Eric1968
                • 2459
                ... and a lot of toner leaking in the machine.
                • expom
                  44 Years in the game
                  • 22
                  Hi Blackcat, i have the problem on a TASKalfa 300ci that does not have a void lead edge on print only causing fuser jams.(copy is fine).Any ideas on how to increase the void from nothing to 3-4m? Registration is fine.
                  • correo.tony
                    • 72
                    Enter in Service Mode with 10871087 and configure margins in SIM 402, lead margin, etc....
                    Bye !!
                      • 22916
                      Bye !!
                      I posted this same answer in your other thread. And I'm pleased that you're searching.
                      There is another possibility though. Another tech may have thought he was doing the customer a favor, and found a way to change this value in FRPO settings. Specifically: FRPO A1, A2, A3, A4 should all be zero. And FRPO D1 should be zero.
                      None of these values are listed on the service status page, so it's hard to say if the values are ignored, or just not displayed.
                      You can just reset these values by sending:
                      !R! FRPO A1,0; FRPO A2,0; FRPO A3,0; FRPO A4,0; FRPO D1,0;EXIT;
                      Or to factory reset all the FRPO settings you can send: !R! FRPO INIT;EXIT;
                      As a final last resort you can try an engine reset: !R! EGRE; EXIT;
                      That should keep you busy for a while. =^..^=
