Kyocera Fs-1118mfp
  • Djamil
    Kyocera Fs-1118mfp
    Hi, I Have Error Code Cf223 On Kyocera Fs-1118mfp.can Anyone Forward Me The Service Manual Or Provide The Solution For This Error Code.
    Djamil
  • JustManuals
    • Jan 2006
    • 9838
    Sure! First post. Just send him the service manual...........
    • leroyal
      Expert on The Obsolete
      • Sep 2007
      • 156
      Main PCB Error. (I hate anything that looks like a KM-1820)
      I know what I know better than anyone else knows what I know.
      • B0265
        • Jan 2007
        • 718
        Have you solved this problem?
        I have a FS-1118 (KM-1820) showing C-F2FF.
        • Yair45
          • Mar 2008
          • 21
          status page lockout on FS-1118
          I have some FS-1118 machines, that when i try to print a status page, i get a critical error, and i can just restart the machine.
          Do you now how can i solve this problem?
          Thank you.
          • golanie
            cf2ff
            Hi Yair
            I have the same problem. the code you get is cf2ff?
            when you start the machin do you see yzamco or kyocera? i think the problem relates to the firmware that get messed due to the Il addition.
            did you solve the problem?
            • JOHNBON
              error Cf2ff
              I fix it by changing the PDL setting to PCL5e,, so go to Printer, device settings,PDL, change to PCL5e
              • josevivas
                Kyocera Mita FS-1128MFP Scan to folder and network related errors
                Hello,
                this is my first por here, i tried to post in the manual section but it says:
                josevivas, you do not have permission to access this page. This could be due to one of several reasons:
                1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
                2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
                If any moderator can take this document to an appropiate place, hope they do please.
                Sorry for any inconvenience but im spanish and my english need a new teacher, all the other are gone.
                Regards
                  • 22946
                  Free Translation and Professional Translation Services from SDL
                  • roguewolftamer
                    Does this include CF26F codes? I have been fighting with this software, as it sends a huge amount of print jobs to the copier. I'm still testing it, but if the problem is better after using the PCL5e driver that would be good to know.
                    I'm working with a Kyocera FS-1128 MFP
                    • ignacio.cortez
                      • Jul 2010
                      • 176
                      Re: Kyocera Fs-1118mfp
                      :-) Blackcat, your translator needs a bit of work, but any Spanish speaking person should be able to understand what you meant, Other than that, it did a fair job :-)
                      FYI :-)
                        • 22946
                        I'm embarrassed to say that I took Spanish classes from the 6th grade through the 12th grade, and cannot remember much. It might have something to do with the 20 years of not using it. Even so, classes do not help a bit with technical language.
                        I am envious of you bi- and tri-lingual members. Some day I'll have the patience and persistence to revive my Spanish.
