Installed a Taskalfa 250ci last week. The previous machine was an Ricoh AF3228C. I made a printout of the network settings and mail server settings on the Ricoh, and programmed these settings into the 250ci.
When I try to scan-to-email the machine displays :
- Network cable not connected
- Hub is not responding
- Server not reachable
When I make a second attempt, immediately after the failed first attempt, the mail will be sent. When you wait for 15 minutes the whole sequence starts again : first attempt fails, second attempt succeeds.
The machine is connected to the same cable as the previous Ricoh machine. I tried to adjust the Time-out setting in the SMTP-screen in Command Center, but no result. IT-Dept. says all is OK with the connection and mail server settings.
Anyone had this before?
