Newbie: Where is Scanner File Utility
  • BHata
    • May 2012
    • 13
    Our office got an old KM-5035 and I am tasked to get it connected to our network which has about 10 Windows systems (XP, Vista, 7). I was given a couple of CDs with documentation and drivers, but they seem old (only thru XP).
    I downloaded all the documents from Kyocera's download center and am trying to understand it all. I don't have ethernet cabling yet so I'm trying to get up to speed just with the documentation.
    I want to configure the KM-5035 to scan to a computer (not sure if 32-bit XP or 64-bit Win7). However I can't seem to find the Scanner File Utility on the Download Center site. Is it part of another package?
    TIA
  • blaze2000
    • Sep 2010
    • 232
    Re: Newbie: Where is Scanner File Utility
    TIA
    Should be on one of the CD's file name is SFU.exe
    • BHata
      • May 2012
      • 13
      The only CD I have is circa 2007 with a Scanner File Utility version 3.16.9.
      Will this work for either 32-bit or 64-bit systems?
      • blaze2000
        • Sep 2010
        • 232
        As I recall, it worked fine on 64 bit versions. I have been out of the Kyocera Mita game for awhile but I remember it working ok, good luck.
        • eddie110171
          • May 2012
          • 133
          3.17.11 is the version currently recommended for XP 64 and 32 bit and 4.11.02 is the version for windows vista and 7 64 and 32 bit. The 3.16.9 might work on the XP.
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            I found it at KYOCERA Document Solutions few weeks ago...had to dig and search for it but I did find it somewhere in there
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • kkendric
              • 301
              Try this Link
              The TASKalfa 305/255 can dramatically lower your TCO total cost of ownership...Kyocera's SMARTtech is affordable
              I am "assuming" that this KM/CS 5035 has a print System and a scanner NIC as well. You will need two connections to the network. One connection for the print system and one for the Scanner NIC.
              • BHata
                • May 2012
                • 13
                Do you know how I can get the latest versions of 4.11.02 and 3.17.11? It's not listed on the Scanner list for the KM-5035 nor the other download sub-categories.
                • BHata
                  • May 2012
                  • 13
                  The scanner utilities site that I checked for the KM-5035 is
                  which does not have the File Utilities. Would you have a link where I can get the latest versions for my copier?
                  TIA
                  • Venom
                    Technical/IT Support
                    • Nov 2009
                    • 765
                    TIA
                    SFU download is only available to dealers, not posted on public site anymore to my knowledge
                    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                    • dickierock
                      • 252
                      I believe Kyocera have dropped their support for Scan File Utility,
                      however it is still available on Utax Site:
                      UTAX UK - Utilities
                      Km5035 = Utax cd1050 just browse for correct model.Software is the same.
                      Hope this helps.
                      • BHata
                        • May 2012
                        • 13
                        UTAX UK - Utilities
                        I checked for Win7 64-bit and they do not have Scan Utility ...
                        Thanks anyway...
                        • autopilot
                          • May 2011
                          • 68
                          Thanks anyway...
                          Just cause it's not listed in the right place doesn't mean it doesn't work. I don't think they are that bothered with keeping it up to date.
                          I'd try it anyway, I've used this on 64bit win7 from the Utax site and had no issues. It may have been under Vista 64 but if it works it works.
                          • kyle miller
                            • Jul 2011
                            • 5
                            Here is a link to the file utility.
                            KYOCERA SCANNER FILE UTILITY V3.11.9.
