Calling to install an MK even after a kit was installed. Kyocera says istall a new kit... Any other way around it?
FS-9530DN calling for MK
Re: FS-9530DN calling for MK
You have to get your kyocera rep to the location or have the help line remote in to reset the counter -
Paul@justmanuals.com
agellen
No way around it other than to install a new kit. The correct sequence is-- unplug the machine, install ALL components, then plug the printer in and run developer in service mode, otherwise an entire pm kit will be for not (will still have install MK message).Comment
I wish I would have known that before we installed that MK. Thank you for your help.Comment
if kyocera are saying replace it with another one, do it and send the faulty one back under warranty with the reason.Comment
I'm going to go and run that code before I do anything else. After that(if it works) I'll beat him up!!Comment
