doc18721720140617101000 (2).pdf
We have a 2500ci which is a Kyocera 2551ci.
The machine had only been out at customer for about a week and it started to print colour bands across the page as in above attachment. Printing in black and white works fine this only happens when you attempt to print in colour.
We ended up swapping the machine and I have been working on it back at the workshop. Naturally after a firmware upgrade didn't fix I just started swapping parts.
So far I have changed:
Transfer Belt
LSU
Main Board
High Voltage Board
Engine Board
Engine Connect Board
These were largely uneducated guesses.
I have printed out the event log and maintenance report and there seems to be a code C7620 registering. The strange thing is this hasn't actually shown up as the usual Machine Failure C code it just seems to keep logging. It refers to ID sensor timing error: colour registration correction failed. I had initially assumed that this was a symptom rather than the cause of the fault but I'm not so sure anymore.
Has anyone had anything similar to this even on other TaskAlfa colour devices?
Transfer Belt
LSU
Main Board
High Voltage Board
Engine Board
