TaskAlfa 3551c1 passwords
  • davidj7
    • 1107
    Hi
    I am asked to install a taskalfa 3551c1 and do some basic configuration .This is the first time i am touching Kyocera . I would like to know the default user name and password for web based configuration (Command Center) also I would like to know how is this model .Is it a solid performer or one that is to be stayed away from.
    David
    a machine is only as good as your tech : source:screwtape ; the scary one
  • darry1322
    • Oct 2010
    • 817
    Re: TaskAlfa 3551c1 passwords
    default username : Admin
    default password : Admin
    Everything else you need to know about Command Center :
    The TASKalfa 305/255 can dramatically lower your TCO total cost of ownership...Kyocera's SMARTtech is affordable
    The 3551ci has been good for our customers.
    PS : if anyone from the Kyocera web team is reading.... the 305/255 series is out of production now. Change the website title.
    • davidj7
      • 1107
      thanks a lot darry
