Kyocera 420i System Menu username and password
  • copyaction
    • Oct 2007
    • 985
    Trying to get into System Menu to set up network info and it is asking for username and password.
    I have tried 4200 and 4200, and every other combination including admin, admin00, no password etc.
    Still keep getting Incorrect Password when I try to log in.
    Is there a way to disable this or has it been changed from default and can it be changed back in sim mode?
    Or will I need to do a memory reset?
  • Kyo fan
    • Dec 2013
    • 368
    Re: Kyocera 420i System Menu username and password
    Try with Admin/Admin (capital A is the key). If it doesn't work you should than reset it with U021, but keep in mind that reset will also wipe event log, so you should print it before, to have some insight into machine's history.
    • kkendric
      • 301
      Login User Name: 42 ppm model: 4200, 52 ppm model: 5200
      Login Password: 42 ppm model: 4200, 52 ppm model: 5200
      Access Level: Machine Administrator
      When the optional Data Security Kit is installed, the login user name and login user password are as shown
      below.
      42 ppm model: 42004200, 52 ppm model: 52005200
      Administrator
      User Name: Admin
      Login User Name: Admin
      Login Password: Admin
      Access Level: Administrator
      • copyaction
        • Oct 2007
        • 985
        below.
        Administrator
        User Name: Admin
        Thanks I reset it with sim 021
        this was asking for a log in as soon as I hit the system menu button, after I reset it it only asked for log in when I entered interface settings and it was 4200 4200
          • 22916
          Most likely you had a particularly anal local IT person that changed the machines administrator password. =^..^=
