... primarily at the left end of the device. In the investigating that I did, I noticed that there was a dusting of toner on the left end of the drum, that wiped off easily with a stretch-N-dust. There does not appear to be any kind of drum cleaning blade or lower cleaning seal, but it does have a foamy cleaning roller, which seems to be making good contact with the drum. The drum has no visible flaws, and appears to be in perfect condition. There did not appear to be any bias voltage applied to the cleaning roller. The cleaning roller is my first potential candidate.
There was no toner dusting anywhere else in the machine. The paper path was clean, front of the developing unit clean, primary charge immaculately clean. There is a broken aligning post on the left main charge block, but it does not appear to affect the way the primary charge fits against the drum. Still, I think perhaps if the primary charge were not close enough to the drum, perhaps diminished primary charge might account for the toner left on the drum.
There were two places to secure the developing unit to the frame, but I think they're just for shipping, so as not to have the developing unit jostling around in the back of the delivery truck. There appears to be a developer shift system a lot like the analog Canon's had, way back.
Let's see, what else? It's got 36000 ft2. Am I working my way in the right direction, or did I miss a fork in the road? =^..^=
