I have created a mailbox that is suppose to scan to a folder on a pc.
The Kip screen shows a connection and when I use "Select" to browse for the folder I see the folder, click on it and open it, then press ok. All is good. The folders are shared. First there is a folder called SCANS then inside that folder is a folder called "scanned". both are shared. I couldnt make it see a folder after it connected until I add the sub folder. In any case it connects all looks good, but when I go and scan, I select black and white the file type is PDF and then select location of pc then scan document. The document shows up on the KIP screen but never gets transferred to the folder called scanned. What is going on? I cant figure it out.
