Brother MFC-9130CW
  • scanmc
    • Mar 2015
    • 178
    [Error Code] Brother MFC-9130CW
    Don't work on Brother units but a customer asked me to look at this. Machine has in the display slide green tab on drum (see attached) My question is how do you determine which drum unit is causing this issue ? I've moved all the corona cleaners back and forth and return them to the home position but the message still persist.
  • Northwestservice
    • Jan 2011
    • 140
    Re: Brother MFC-9130CW
    i work on brother but it is a difficult as no parts available from brother. basically there is a short to ground in the high voltage (the corona wire is shorting out to ground) look closely at all corona assy. you may find a piece of lint or a cat hair, you could try bowing out with air. good luck
    • Dickie
      • Nov 2011
      • 190
      This is usually caused by customers ignoring the change drum soon message as Brother products do not stop when drum life reaches end.
      Go to reports and print out the user settings report
      At the bottom will be a series of rectangles indicating life remaining for each of the consumables
      It blocks in in black the remaining life so if you have a wholly white rectangle then that part is at end of life.
      Also can be caused by using non original toners that leave a coating on the drums.
      The machine is looking at the potential difference between a charged and non charged area and when the gap closes because either the drum is coated or worn it throws this message
      Hope this helps
      • scanmc
        • Mar 2015
        • 178
        Hope this helps
        Thanks! I'll print out the report and get the life status and go from there
          • 22801
          did you clean the contacts on the inside of the machine and the drums ( on sides )? I have had this happen before... you should go to maintenance mode 80 and look at the error code it might give you more info. More often than not the drums need to be replaced.
          • ricoh_rockstar
            • Apr 2016
            • 18
            If the problem persists after cleaning the corona wires, the drums electrical contacs and the ones inside the machine, you will need to replace the drum units, they probably reached the end of its service life.
            Mfr Part #: Brother DR221CL
            After replacing them, dont forget to reset the counter:
            • dalewb74
              • Feb 2018
              • 1107
              are you sure the slider is locked into the home position. you can slide it and it will stop. but pressing a little bit more you will feel it move slightly into the home position. just a simple check you might have done already on all of the drums.
