KIP 7170 error codes
  • dwarf
    • Oct 2012
    • 168
    [Error Code] KIP 7170 error codes
    we need some help with a KIP 7170 error... the first one is E 070...the second one is E 0(3059)...can anyone offer some guidance as how to deal with either or both codes... error persist even after a reboot...thanks for the help in advance...
    • 22916
    Re: KIP 7170 error codes
    E-070 is a Developer Set error ... that is, either the developing unit isn't plugged in or the toner door interlock MS4 is not made. To view the developing unit remove the toner door (don't drop the brass washers on the doorstraps into the machine, they're really hard to get out) > remove (4) screws from the front cover > the front door will swing down to show the developing unit.
    Interlock MS4 is item #3 in this illustration:
    I have no idea what E 0(3059) is supposed to be (is that syntax correct?).
    • venluckey
      • 36
      Found some talk about this on another forum,
      KeepItPrinting.com :: View topic - 7170 rollfeed error
      Maybe it will be useful.
