Epson TM-C7500G
  • Profibastler
    • Nov 2014
    • 93
    Epson TM-C7500G
    Hi technicians!
    Every printig and every turn on before, printer will start print head maintenance 0/1 to clean the printhead.
    Print quality is not soo bad, 6 nozzles missing only, newest firmware WAI34400 installed.
    How to deactivate the automatic cleaning?
    THX for help
    • 8062
    To adjust the print head cleaning frequency on your Epson CW-C7500, you can follow these steps:
    1. Access the Printer Settings: Open the printer's control panel or the printer management software on your computer.
    2. Navigate to Maintenance Settings: Look for a section related to maintenance or print head cleaning.
    3. Adjust Cleaning Frequency: You should find an option to set the frequency of automatic print head cleaning. You can reduce the frequency or disable it if the option is available.
    For detailed instructions, you might want to refer to the Epson CW-C7500 Technical Reference Guide
    1
    • Profibastler
      • Nov 2014
      • 93
      Disabled nozzle verification technology. No cleaning during prints. But need service manual to change the heads, please?
