111# Cover translates to 300gsm
80# Text translates to 116gsm
You didn't specify what inkjet you have, but your inkjet will most likely be able to handle this stock, especially if it has a straight paper path.
I most certainly would not run this through a laser device. Metallic papers deposit metallic (read "conductive") particles into the paper path eventually shorting out components applying high voltage, like transfer, developer bias & primary charge.
Yes for inkjet ... Never on laser based devices. =^..^=
Hi,
I used the Epson WF C21000 and having poor print quality on Ice Silver
But if I print on a Laser printer Ice silver prints good quality.
You mean that the paper you recommend is recommended for Laser printer?
No. Never use metallic coated paper of any sort on laser based devices.
I did not recommend either of those papers. I was just confirming that was what you were talking about.
"Coated on both sides and available in text and cover weight"
If it is coated, this is the most likely cause of issues with ink as it cannot absorb into the paper. Toner is heated and pressed onto the page, its why the copier is working, and the ink is not.
... I very much suspect that the exotic media you have selected is not supported by your A3 business class inkjet printer. I do not know Epson very well but somewhere they must publish their acceptable media types.
You should be looking at the 4" wide Epson Colorworks CW4000 label printer.
