I just picked up a Panasonic DP-C265. I have several issues trying to make this do anything:
1. Right off the bat when in the Copy mode, it comes up with a request for a passcode to do anything. I tried the "00000000" but did not accept it. So the copy function is stuck there. How can I reset or find out what this pass code is? I am able to get into the configure mode, but do not see any clues how this could be changed.
2. Question - does this work with Windows 10? I downloaded the driver which specified windows 10 as one of the OS's listed. However, the driver did not detect the printer. I also pinged the IP address set up (192.168.1.111) but got no response.
3. I tried going the USB route, but when it requested me to plug in the USB, I heard the traditional "connect sound", but the setup dialog box refused to highlight the next button and was stuck there with only cancel available...
3. Is there a way to reset this machine to factory settings?
Help with any of above issues would be greatly appreciated!
Thanks so much in advance!
