panasonic DP-8060 Error code E03-03
  • vmchong
    • Oct 2008
    • 22
    [Error Code] panasonic DP-8060 Error code E03-03
    Run f8-09 after pm code E03-03 please help!
  • doug94550
    • Dec 2011
    • 138
    Re: panasonic DP-8060 Error code E03-03
    E3-03 is your toner density sensor. Check the harness and how does the face of it look? If it's really worn, you will need to replace it. Try swapping it with another.
    Doug
    • vmchong
      • Oct 2008
      • 22
      Thank you for the prompt replied. I did swap the harness and the sensor but no help. I tested the spcboard cn720 24v ok.
      ??? no idea.
      • doug94550
        • Dec 2011
        • 138
        Hmmm...
        Could be the harness between the Spc and the dev assy.
        Also, take a look at the coupling between the dev assy and the mainframe. I have seen some of them crack.
        Doug
