This is a fuser error. Select these keys sequentially, Function>Original Size>3. Then enter 00000000>set key. You should see F1 displayed. Scroll to F9 then set. Not to sure on the rest, but I think this. 06>set. 04>set. Turn machine off then on.
With some machines selecting the start key may work in place of the set key. Not sure on this one.
You want to get to F9-06-04 to reset a fuser code.
Hope this helps. If not, try posting this in the Panasonic forum of Copytechnet.
