I have a customer with the Ricoh Aficio MP C4500 printer. It's worked fine for a few years, and then yesterday they reported that it gradually stopped working during the morning. When I remoted in, I found that I can ping the printer, I can view the WIM, I can even telnet to 9100 and send commands (and get a error response because I'm not sending the right commands), but I cannot add the printer to a PC and I can't print from PCs that already had the printer installed (95% of the time).
Maybe 3 times today it successfully printed test pages from different PCs, but then wouldn't print again. We tried changing the static IP of the printer, we changed network ports on the Cisco switch, rebooted the switch and the router. I had them check the protocols via the control panel and the only thing disabled is NetWare and Bonjour (disabled while I was testing, it's a Win7 only environment).
Any ideas? I'm leaning towards a hardware issue with the printer at this point, but there could be something I'm missing. We've power-cycled the printer several times, including unplugging from the wall. Any other diagnostics we can do?
