Problem when adding new Developer to Ricoh MPC 6501 MPC 7501
  • Guest
    I added new developer to MPC6000 and MPC7500 , Easily by using SP3814 and the results in SP3815 are good "1111"
    Each time I'm trying to follow the same procedure for MPc7501 or MPC6501 and after I closing the front door and open the power on, The machine stop and give me a massage that it can't detect the toner and an arrows appear for each toner on the screen, so i can't use the SP3814
    i'm sure that i followed the same procedures specially " keeping the lever of transfer belt down ", and closing the front door before opening the machine
    How can i add the developer by SP3814 without failure
    Thank you
  • Zaxxon
    • 608
    Re: Problem when adding new Developer to Ricoh MPC 6501 MPC 7501
    Thank you
    The developunit should be totally empty for old developer as in EMPTY or it will kick your butt...
    Please start you post with brand, model, problem.
    • Guest
      Thank you Zaxxon ,
      but already the developer unit is empty and i'm using blower for cleaning
        • 36694
        My suggestion is to follow the service manual step by step. Unless you are doing a procedure on a daily basis, do not try to do it from memory.
        • turbojetboy
          • Aug 2009
          • 279
          Thank you
          Check the photointeruptor on the rear of the itb assy that checks the poistion of the blue transfer handle. These can become dislodged etc.
          • Besserwisser
            • 25
            You talk about MPC6000 and MPC 6501, are you using the same developer as 6000 to 6501 ?! if so there is your problem...D014/D081...
            • CRISTIAN MULLER
              • Feb 2013
              • 145
              I always have this problem, what I do is follow the service manual procedure until this point, at this point enter in service mode and turn develop motor for the color that you want to fill the developer, use the lower speed possible and be sure that developer case are secure in place.after that follow the rest of procedure by the manual. Don't forget after you put toner hopper and power on the machine, do it with door open, enter service mode and now you close the door.doing this you will prevent the machine to do process control and mess with toner concentration. After enter service mode with door open, close it and do dev setup execute.3811 if I remember. Do this for all color and you are good to go.
              This is a know error for this model in service manual.
              • TonerMunkeh
                Professional Moron
                • 3869
                The Venus dev fill procedure is a total bitch. If the machine asks for the toner hopper to be set prior to dev fill, the TD sensor is still detecting developer. You'd be best off vacuuming the living death out of the dev unit, turning the mag roller, vacuuming again and making sure absolutely no developer is left on the mag roller when you turn it. That's when you know it is completely empty of the old dev.
                Hit it.
                • Guest
                  thank you for your answer
                  i did my best to clean the tank but still the same problem
                  so t used the "CRISTIAN MULLER 's" way , I used 5804-099 , -100,-101-102 to run developer motor
                  and it's working
                  thank you
                  • Guest
                    Thank you "CRISTIAN MULLER " I follow your recommendations and it's working i used 2804-100 for M , and used 5820-002 then 5801
                    thanks again
                    • Guest
                      My problem is why this not happens with MPC6000 or MPC7500, it happened only with MPC6501 or 7501
                      thank you for your reply
                      • Guest
                        I totally removed the cable from the sensor in the back of ITB, and not working
                        I used CRISTIAN MULLER way " read it
                        thank you
                        • Guest
                          thanks again
                          Sorry there is a mistake in number a
                          5804 not 2804
                          3820 not 5820
                          3801 not 5801
