tried it but it just started making a copy HELD IT FOR 20 SECONDS OR LONGER
Oops! My bad. I guess they must have changed the procedure on the newer versions of those little things, the same as they did for the copier based machines.
Try this: Clear/Stop-#-107-Start and hold. Machine must say "Ready" on panel before it will work. You can get it to say ready, if if a code is showing. This procedure works on the 3410sf
