SC202 Ricoh MP9000
  • Andrei88
    • Jan 2016
    • 6
    [Error Code] SC202 Ricoh MP9000
    Hi! Error Code SC202 at Ricoh MP9000! Please help! Thanks!
  • antoney suresh das
    • May 2011
    • 103
    Re: SC202 Ricoh MP9000
    hi,
    the code sc202 relates to the laser motor the failure of the unit is rare i would advise you to check the cooling system of the machine clear all the carbon filters thoroughly and ensure all the fans are running properly keep the machine at least 10 inches from the wall.
    • Codex
      • May 2008
      • 693
      Originally posted by antoney suresh das
      hi,
      Had the same issue with two MP9000, check or change the door switches, in one machine i had to change the Laser Diode, the other one starts after the door switch change
      Memento Audere Semper
