MP201 Windows 10 scan to folder
  • Dark Helmet
    • May 2009
    • 829
    Hey guys, has any body been able to make a MP 201 scan to windows 10 folder?
    Ive done all my tricks i normally do for Windows 7 and i have had no luck with this thing.
    I know the older copiers don't support SMB 3.0 or something along those lines and they can't scan but MP201 is a current model. I checked TRSC site and the newest firmware is from 2014 for NetworkDocBox.
    Any body else had any luck?
  • rthonpm
    • Aug 2007
    • 2849
    Re: MP201 Windows 10 scan to folder
    You want the Network Support firmware, not NetDocBox. The 201 should have an update for Windows 8/Server 2012, which were the first versions of Windows to use SMB 3. Go ahead and update everything and try setting up everything again.
    • Dark Helmet
      • May 2009
      • 829
      I went back to the TRSC and found a special firmware that takes care of this issue.
      D115
      2/25/2013
      The following SMB-based GW functions will work with Windows 8 and Windows Server 2012 with this firmware.
      D115
      2/25/2013
      If you are logged into TRSC those links should download the proper file.
      Thanks!
      • mikedci
        • Jul 2010
        • 227
        fwiw latest network firmware is
        D069_D115_NCS_v907_SDcard
        http://rfg-esource.ricoh-usa.com/ora.../rfg037022.zip
        there is also newer custom network firmware for the browser https issue
        • afterhours
          • Mar 2017
          • 152
          Originally posted by mikedci
          I realize this is a very old Thread, but is there any way that you can provide this firmware? Id be willing to purchase firmware that would allow a Ricoh 201 to scan to windows 10.
          Im a Loser Baby!!!
            • 36689
            I would advise that you start a new thread. Many of us old farts who would have the firmware don't appreciate grave robbers.
            • anothertech
              • 1755
              If you are willing to pay for the firmware, place a call on the machine and a Ricoh tech will come and update it.
                • 29306
                Just either use scan to email or scan via ftp using filezilla server
                • Tatteous
                  • May 2017
                  • 24
                  All firmware needs to be current especially NCS.
                  Win 10 has more steps. Try this..
                  • sandmanmac
                    • 3967
                    You're quoting the guy that started this thread over 2 years ago, and it was resolved in short order, and he returned to update us that it was a firmware issue.
                    Input and Advice is appreciated, but please take the time to read suggestions and solutions before weighing in. You'll actually be amazed at how much you learn yourself.
                    • sergo
                      Hi all. Have the same problem.
                      I don`t have access to ricoh official site.
                      Help please, need firmware for mp 201 spf with network version 9.07.
                      Thanks.
                        • 22801
                        Thanks.
                        did you READ all the posts in the OLD (dead) thread?
                        there were even LINKS posted to the FW.
                        • Malins
                          • Dec 2019
                          • 4
                          And how to download 9.07 if all links do not work? There is only one working on 9.06.
                          • Malins
                            • Dec 2019
                            • 4
                            Сам нашёл, спасибо.
                            Работает на MP 201 и MP 171.
                            Ricoh firmware
                            Ссылка на NIB 9.07
                            Так же есть полный набор прошивок.
                            • anothertech
                              • 1755
                              Сам нашёл, спасибо.
                              Ricoh firmware
                              Ссылка на NIB 9.07
                              Seriously? You are going to post in Russian? Come on comrade!
