MPC 3002 SC 574
  • Hoosierdaddy
    • Oct 2016
    • 181
    MPC 3002 SC 574
    This machine has a SC 574 code. The press roller thermistors were dirty so I cleaned them and then replaced them after the code wouldnt Reset. I also replaced the Heat Sleeve Assembly because it showed wear. Along with the reset fuse. I did a SP 5810-1 and -2. NO Change ANy suggestions?????
    Thanks Hoosierdaddy
  • anothertech
    • 1755
    Re: MPC 3002 SC 574
    Have you followed TSB-009? What does SP1-106-001 to -004 indicate?
    • copier tech
      • 8091
      Re: MPC 3002 SC 574
      I had a 3002 that had this issue, firmware still had years old factory versions, updated all the files, then I was able to reset the error with SP5810-02
      • Hoosierdaddy
        • Oct 2016
        • 181
        Re: MPC 3002 SC 574
        It has the firmware with that SP option. When using that SP 5810-2 it said failed😟
        • mikadonovan
          • May 2008
          • 2936
          Re: MPC 3002 SC 574
          If it wont reset, it sounds like you have a fusing component that has failed, like a thermistor (check fusing temp display in sp1xxx to isolate), or maybe a thermostat is blown, or one of the lamps in the new fusing sleeve assembly is bad (I have seen that a couple of times).
          NEVER ASSUME ANYTHING
          • eddy out
            • Oct 2016
            • 359
            Re: MPC 3002 SC 574
            there is a fuse in the unit that must be replaced before performing that sp reset.
            • mikadonovan
              • May 2008
              • 2936
              Re: MPC 3002 SC 574
              Read his first post. He already did that.
              • Hoosierdaddy
                • Oct 2016
                • 181
                Re: MPC 3002 SC 574
                I figured it out!! After looking at another fuser I found that I had plugged the Fuse into the Thermistor Plug (Why they have them with the same plug on them is beyond ME. I wont make that mistake again!! thanks for all the input. Have a good evening
                • mikadonovan
                  • May 2008
                  • 2936
                  Re: MPC 3002 SC 574
                  Glad you got er figured out, and thanks for the follow up.
