I ran out of time Friday when customer called but was able to print out a solid test pattern. He has another 5501 so with the time I had I did a quick swap of the PCU(K) and ITB with no change. Color is not effected! Any idea's before I return! (See attached photo) Thanks for all your help!
Ricoh MPC5501 White spots in solid area
Re: Ricoh MPC5501 White spots in solid area
Looks a bit like the 'firefly effect' with really bad developer in the black. You say you swapped the black pcu? The whole thing inc the dev unit or just the pcu?Comment
Pattern is very similar to the one I had on a Pro 8110 from a bad transfer roller in the ITB. Simce you said that you swapped the ITB I'll go with the PTR. Either that or you have two ITB units with bad black transfer rollers.Comment
Follow up! The spring behind the ITB for the "K" transfer was barely hanging on! Replaced spring out of a junker and all is well! Have no idea how the spring got that way unless a tech was replacing a toner pump and accidentally snagged it. Thanks for everyone's help!Comment
