MPc6000 can not access web monitor?
  • aalex_bom
    • Jan 2008
    • 214
    I have a MPC6000, I installed printer driver for PS or PCL6 through TCP/IP but can not printing, but I scan to PC/Folder , that ok
    I've tried access WEB Monitor with IP same but can not , show 403 forbidden error.
    I tested Ip port with command Ping, it connected successful.
    Any suggestions?
  • NeoMatrix
    Senior Tech.
    • 3514
    Re: MPc6000 can not access web monitor?
    Telnet into the MFP and set "Web Up" (no quotes). Log out and save as prompted with correct log out process.
    Resetting the NCS should reset the Web Access as well.
    • aalex_bom
      • Jan 2008
      • 214
      Originally posted by terramobil
      Try to reset NCS and printer settings, 5-801-011 and 5-801-008. This will delete all network settings, after that you have to set network data again.
      thanks Neo," web: up " I see HTTP: Up
      image1.JPG,
      I updated FW, every parameter is ok.
      whats wrong?
      Can you help me!!
      • davel
        • Oct 2011
        • 1076
        Was it working before, should it have a fiery connected, update the old POS.
        • aalex_bom
          • Jan 2008
          • 214
          I think it's the "Access Control Range [1]" delete the data and it should work. It does not match your IP settings.
          how do you change , can you say detail for me!
          It is not use Fiery Server before!
          • aalex_bom
            • Jan 2008
            • 214
            [QUOTE=terramobil;545601]
            Set the divice to an IP address within the accessable IP address range. Set your laptop to another IP within that range and connect it directly to the device. Enter WIM and change settings (configuration/security).
            ok, thanks terrammobil; it have changed successful, thanks everyone!!!
