SC 672 - 11
  • lloydy83
    • Feb 2017
    • 8
    SC 672 - 11
    I have a new MP C307, it has given the error code SC 672 - 11. It says its the communication between the ops panel and board. I have swapped the panel and still throws this error. Before i replace the board has anyone had this error or can help me out.
  • lloydy83
    • Feb 2017
    • 8
    Re: SC 672 - 11
    Yes i have checked the dip switches...looks like i'm going to have to change the board.....thank you
    • TonerMunkeh
      Professional Moron
      • 3869
      Re: SC 672 - 11
      If it's a fax model, the MBU jumper being OFF can also cause this code.
      Hit it.
        • 36733
        Re: SC 672 - 11
        I have seen the USB cable between the Op panel and the controller board cause problems.
        • Polarbear
          • Feb 2012
          • 1070
          Re: SC 672 - 11
          Had one just now where some genius had uplugged the USB cable from the board, and sure enough SC670-11 popped up right away!
          Press the GREEN button!!
          • monstercopier
            • Jun 2019
            • 50
            Re: SC 672 - 11
            Does anyone know the part number for that USB cable?? I rather not remove it from another machine if I don't have too.
            • Polarbear
              • Feb 2012
              • 1070
              Re: SC 672 - 11
              You can try D2965247. Found it on the point to point diagram. No reference in the parts manuaul.
              • General Copiers
                • Feb 2020
                • 26
                Re: SC 672 - 11
                I had the same error code in a MPC3003. You can find the solution by following this post:
                Ethernet error + SC672-11 with new NVRAM on Ricoh MPC3003
