Hello ladies and gents,
So We received in two used copiers, one 4503 and one 5503. I have just tried to install the 4503 and discovered the ethernet port may be dead. The 5503 had an ethernet card I pulled out and installed in the 4503. But after I made sure the ethernet and usb were enabled in SP mode, ip address was set correct I cannot ping anything nor get to the copier in web access. We have about 10 other copiers that do work in the building. I tried hooking up the 5503 as well and it didnt want to reach anything on the network as well.
Thoughts? Is there some hidden setting in SP mode that I am missing?
